Mes maquettes inspireés par la realité Portugaise
Messagepar Abran » 05 04 2008 à 23:23
Reste plus qu'a faire passer une motrice de Lisbonne, de chez Halling entre autres !
Messagepar schmalspurganove » 06 04 2008 à 18:19
Hello,
I thought about putting the rails of the eletrico in front of the buttom station when I made the plan for the layout, because I also have some models of this nice lisbon trams.
http://a355.ac-images.myspacecdn.com/im ... 787a9a.jpg
but then I decided to cut off the scene in front of the pavement, to focus on the elevador. If once I have a bigger shelf I can add some cm for the tramway rails... ;)
In the moment the size of the layout is 84x28cm.
I took some pictures showing the whole layout. You can see that there is still a lot of work to do: :wink:
http://a142.ac-images.myspacecdn.com/im ... 302b1d.jpg
http://a888.ac-images.myspacecdn.com/im ... 630cef.jpg
http://a197.ac-images.myspacecdn.com/im ... 21ec94.jpg
http://a350.ac-images.myspacecdn.com/im ... ec372d.jpg
greetings, :wink:
Ralf
schmalspurganove
Messagepar malletslm » 06 04 2008 à 19:26
GREAT job Ralf !!! :shock: E4 E2 E3
Please allow me to modify slightly your message, so the pictures will be seen...
schmalspurganove a écrit:Hello,
greetings, :wink:
Ralf
I really like #A4 the last picture !
Like Abran and you, I also have these H0 Lisbon "electricos"... Here is a little "Amarelis" I modified to match a single-end "remodelado" (541-585 serie) of 1995...
[center]<img src="http://jmcityrunner.noosblog.fr/Lisbon11.jpg" width=" 480">
<img src="http://jmcityrunner.noosblog.fr/Lisbon12.jpg" width=" 480">
<img src="http://jmcityrunner.noosblog.fr/Lisbon9.jpg" width=" 480">[/center]
... and as you can see, it is supposed to run on the "carreira 25" (Alfandega-Prazeres)... #B5
Messagepar schmalspurganove » 06 04 2008 à 21:50
Thanks alot malletslm for showing my pictures. its much better like that. E2
Very good your modifications of the amarelis electrico. looks quite authentic with the two phantographs. only the kids are missing that ride outside on the back platforms of the train without paying... :wink:
I really like these die cast models. i motorized mine with a halling h0m "varioantrieb",which fits quite good inside the tram and has the correct wheelbase...
schmalspurganove
Messagepar malletslm » 06 04 2008 à 22:28
schmalspurganove a écrit:Thanks alot malletslm for showing my pictures. its much better like that. E2...
H3 H3 H3 :D
You only have to use the "Img" symbols at both side of the link, like this:
[img]http://image%20etc...%20.jpg[/img]
and the picture will appear...
schmalspurganove a écrit:... Very good your modifications of the amarelis electrico. looks quite authentic with the two phantographs. only the kids are missing that ride outside on the back platforms of the train without paying... :wink:...
Excellent Idea !!! :699 ... WHY did I not think it earlier ? :paf
schmalspurganove a écrit:... I really like these die cast models. i motorized mine with a halling h0m "varioantrieb",which fits quite good inside the tram and has the correct wheelbase...
Yes ! #B6
None of my "Amarelis" have motors, but I used the sides of a Halling plastic chassis on this model, to evoke an old "bidireccionais" (double-ended) with the "Brill" style truck...
[center]<img src="http://jmcityrunner.noosblog.fr/Lisboa4.JPG" width=" 480">[/center]
PS: j'espère que PME nous pardonnera cet aparté en langue étrangère ! (je n'ose pas trop dire "en anglais" dans mon cas...) :wink:
Messagepar marc_reusser » 08 04 2008 à 09:18
Wow Ralf! :C4 :C3 Mensch, das Dio ist also der absolute Hammer!! Wirklich eins der kreativsten und wundervollsten Ideen die Ich in langer Zeit gesehen habe! ...und darauf noch sehr schoen Gebaut! H3 H3
[L'homme, le Dieu, c'est donc le marteau absolue! En fait, une des plus créatives et les plus merveilleuses idées de longue date, je n'ai vu! ... Et rappelle encore très bien construit!]
Marc
marc_reusser
Un Samedi au "Ascensor da Bica"
Messagepar nalmeida » 30 04 2008 à 00:08
Like I promised I went to the "Ascensor da Bica" to take a few more pictures for Ralf, here are two of them:
and
Ralf, send me your email so I can send you the rest.
nalmeida
Messagepar pelican » 30 04 2008 à 08:20
un grand merci pour les photos !! on apperçoit bien le bricolage de pantographes pour capter le courant lumière ! #B6
Messagepar fantrains » 30 04 2008 à 11:09
Superbe travail,
merci de nous faire partager ce bonheur.
E2
fantrains
Localisation: Avallon mais souvent dans la lune ou ailleurs
Messagepar schmalspurganove » 01 05 2008 à 16:59
merci beaucoup Nalmeida,
E3 E4 E2
I sent you a mp with my e-mail adress. I'm very curious about the pictures. they will help me a lot to complete the model.
muito muito obrigado,
Many greetings from munich,
Ralf
schmalspurganove
